Expidia
- Aug 26, 2006
- 2,374
As I was pulling up next to the dock a few days ago my Overtons.com Sunbrella Bimini frame snapped in two as the boat jumped up from a passing wave and just caught on the top of a post right where the back third bow connects. This caused the whole top to collapse
Now in hindsight, there is something to be said for getting a stainless frame instead of aluminum. But I'm mostly fresh water and I went with aluminum to save a few bucks and less weight too!
So I thought I'd have to replace a good portion of the frame (which is made by Westland).
So I took it down to my basement work shop to see if I could fix it somehow since I needed it for today's outing. No bimini means no place to attach my enclosure and thunder showers were predicted for today.
I'm posting this thread for others to make a note how I luckily came up with an amazingly simple fix. So now I had the right side of the main frame tube in two pieces and had to figure out a way to connect them back together. I looked inside the frame tubing and there is actually another smaller diameter tube inside the frame.
For the hell of it I grabbed a 3 foot length of copper tubing that I keep around in case a copper water pipe freezes and splits open over the winter.
I tried to insert it into the inner tube and to my amazement it was a "perfect" fit. A standard what looks to be 3/4 (measures a little less) copper tubing fits was like it was ordered special for this repair! Had to twist and turn it cause it's a very snug fit, but I was able to get 1 1/2 feet of the 3 foot tube into each section. I slid the plastic jaw slide back on which holds the 3rd bow to the frame and drilled a starter hole into the frame and thru the copper tubing to hold the slide stationary like it was originally. I drilled two small extra holes 1 above the slide and one below to keep the copper tube from moving inside the tube and used 3 stainless steel self tapping screws.
Used the bimini and the enclosure all day today and the repaired side is probably stronger than new and it can't be seen that it was ever broken.
I don't know if copper is going to react with the metal inside the frame tube over time, but if it does I would have had to buy a replacement frame section anyway, if I couldn't repair it myself.
So just a tip . . . if you snap your 3/4 inch bimini frame a length of standard copper tubing can be inserted into the frame for a perfect repair
