Barkin Buddy
- Aug 7, 2018
- 13
I've owned my '89 Bass Tracker 1800 FS for about 2 years now and finally have the chance to get the livewells working. The pumps are not working and the valve cable levers are broken from the valves. My problem is that I don't know how it all worked originally. The pics show the way it is plumbed.
To fill it looks simple. Pull the knob to 'FILL' position to close off tube no. 2 and flip the aerator switch to "MANUAL". Turn the aerator off when it reaches the overflow. I don't see any reason to plug the livewell to keep it filled unless the valve leaks.
Draining looks simple too. Push the knob to 'DRAIN' which opens the valve completely to drain it. Guessing the boat has to be on plane to drain though.
How do you operate the "AUTO" feature? Is this for re-circulation? Is there a timer? I'm not sure how a 2-position, open or closed valve like this would allow for re-circulation. Is something missing? I have a feeling the 'SENSITIVETY' dial is for the old depth sounder but suppose it could be for the livewell.
I want to buy new valves and if I can't get the pumps going then buy some new pumps. Can anyone recommend a valve style. I figure a FLOW-RITE brand type 1 valve would be the correct replacement.
I look forward to any input.
