dream-builder
- Feb 5, 2020
- 1
So I need to replace my shaft seal which means I have to remove the shaft hub which means I need to replace the shaft hub.
So if I replace it with with s Split hub, does it really need to be fit and faced?
If I use a split hub is it really reusable if I ever have to take it apart again?
And if you can not reuse a split hub down the road is there really any reason to spend the extra money for one?
