crazy charlie
- May 22, 2003
- 5,386
I have owned my Regal commodore for over 10 years.My water system can work off my manually filled water holding tank or Hose inlet shore feed from the dock.When plugged into shore inlet for an extended period while on vacation I noticed that my water holding tank is filling up which it has never done nor did I think it was possible to do.This has never happened before as I typically keep the tank near empty when on boat vacation and plugged into shore water/hose inlet.My guess is that I have a bad check valve somewhere allowing water to flow into the tank and actually was trickling out of the cap.fill.Anyone very familiar with watre systems???
