- Mar 8, 2009
- 43,633
I'm on my 4th complete shower bilge, have 3 sitting on the shelf. Last one bought had the Sarhara 500S pump. Looked like a good self contained pump with built in float switch. This is the first year for this shower bilge. During winterization I did the usual and soaked up all liquid and put boat to bed.
This year I'm adding water to the tank and letting water flow thru the system, and to keep it short the bilge pump is not pumping. Check voltage and it has power but does not run. Removed pump, turn upside down and still nothing. So removed and cut it open.
From the pics the unit is glued shut except for where the wires come in. Its a little rubber grommet of such which could not stand up to maybe 1 to 1.5 inches of water above it. Its in a shower bilge so its not deep.
Have Johnson, Rule and others, but the Attwood seams to be a non-starter without modifications. May be ok if it was sealed better, maybe take some silicone or 3M 4200 where the wires are
