Yes Thanks! I lost a battery last year that should've lasted at least a couple more years. Had a feeling it was a winter issue.
Thanks again,
Batteries stored in colder the better as far as discharge is concerned as long as they don't freeze. Storing them in a heated area will cause them to discharge faster! I keep batteries on a 3 stage charger 24/7 during the winter if I can. If I can't keep them on a charger, I charge them up once they get down to 12.5 volts.
Sometimes a trickle charger will boil the batteries depending on the trickle charger. They should only be at a float voltage of a round 13.5 when the battery is fully charged. If the voltage is higher than that, you need a better charger.
None of my boats are at a place with power in the winter, and I usually manage 7+ years out of boat batteries. Disconnect the negative cable, and reconnect in the spring. If for some reason a battery would ever freeze, the battery was shot before it froze anyway, so time to replace.
4 wheeler batteries, snowmobile batteries basically the smaller rec equipment batteries seem to have a much harder time in the extreme cold.
How do you keep those warm in the winter?
I average 3 years on my snowmobile batteries no matter what I do, always three years. My sleds don't have a pull-start backup, so I tend to replace them at the first hint of failure, and I'm too cheap to go to some of the lightweight high dollar lithium's.
Some years ago I had an end-of-life car battery and I wanted to reclaim the lead inside for another purpose. So, I drained out the electrolyte and filled it with water. Put it in the back yard for an entire Buffalo Winter. I thought a frozen battery would be easier to break open.Whereas I have had fully charged, expensive boat batteries freeze in an unheated garage
No chance. No damage at all to the case. How DO you get a battery to freeze?
