Good day, I have a Monterey 262 2001 and the hinge pin from the front windshield window is breaking, Im looking for the replacement but cannot find a specific. Does anyone have any idea of a part number if possible.
Piece of stainless steel tig welding rod you can pick on thats got a higher corrosion resistance if you can find a shop that does a lot of TIG welding on stainless. Put a light flatten on the last end to slide in enough that it will need driven in with a punch and it will stay put
I hope you have better luck with Monterey than I did, they were never able to help me with any specific parts requests. 3 years with a 2004 226 and I eventually just quit trying the dealerships. Fortunately there is very little on a boat that is specific to the manufacturer, so with a little searching and creativity you should be able to find a similar part.
