As per wellcraft, that boat uses foam filled fiberglass stringers and composite transom. Technically, glass over plywood qualifies as a composite, but with boating in the past 20 years, composite usually means plastic/foam/etc. For info on older wellcrafts you can go to the owners section of their website and they’ve got old literature and brochures that at least provide some pics and specs.
