I have checked many things but still no clue.
1. The boat is sitting on trailer, the outboard is 115 hp and sitting upright. The wheel is smooth and can be turned with one finger to turn right and left. But to left, I always have to use a stronger finger than to turn right.
2. On water, this situation is more obvious. One hand to turn right, and two hand to make it turn left, I mean the wheel.
3. I dis-attached the link to outboard, and the wheel can turn very freely left or right.
4. With the outboard standalone and upright, the engine can turned by hand freely to left or to right. But I can tell it is harder to one side than the other, though it is not that obviously.
5. I squeezed out the old grease with fresh marine grease on outboard rotation area.
My guess is,
1. steering helm problem. It is harder to turn one side than to the other side.
2. Outboard mounting rotation problem. It is not mounted even level, which make it weight more on one side.
Anyone has similar problems and any suggestions are appreciated.
Thank you.
My guess is,
Thank you.
