BridgeTT
- May 13, 2015
- 7
Hi All,
I'm new here but not new to boating. I've been purchasing parts from boatsdotnet and stumbled across this forum. It seems like there's a lot of experienced Yamaha users and technicians here and I'm really hoping someone could give me some insight to some problems I've been experiencing with this 250TXRR Outboard. In a nutshell, here's what happened. I purchased a new Yamaha 150HP approx. 10 years ago after running away from old motor problems and that motor was sweet but got stolen. My boat have been parked up since and someone gave me what I thought was a steal of a deal by selling me a 250TXRR motor which sounded pretty good and powerful but I think I bounced my head. The motor only ran good once but I've been plagued by surging and bogging down issues. To me, the 150HP performed a lot better than this 250HP. This is the same reason why I ended up purchasing a new engine to get away from engine troubles, who wants an unreliable engine on a boat in open seas?
I might need to mention at this point that at first, I didn't know the engine was missing anything until I started troubleshooting. This engine was 'converted' to pre-mix in that it's missing all the oil injection components except for the main oil tank sensor. At the first sign of problems, I serviced the carbs. The engine had problems starting and idling, now that's gone but I never got back that power @ WOT. It was surging at some point and figured it's the low pressure fuel pumps but I decided to check out all other components. Now my tach was working with my new engine before but with this engine, it's dead so I'm not sure at what conditions are happening at what rpm. I read somewhere I could connect the tach directly to the green wire from the rectifier and I got a reading but when I increased the throttle, there was no increase in rpm on the tach. Also, when the engine was struggling at low rpms, I changed the plugs and it performed good for a brief period, then started doing the same thing. I'm basically getting 'trawling' speed. My boat used to do around 30-40mph with the new 150HP and I have patience but I'm not able to enjoy my boat and spending more time fixing than fishing. :faint2: I've gotten the seloc manual for this engine and I'm going through everything step by step but somehow I'm not getting anywhere. After I changed the plugs and got a momentary boost in performance, I checked the plugs and 3 of the 6 were wet. I assumed the ignition coils but checking each plug generated a spark. I'm not sure if it's weak but I don't know if someone can advise me if I'm going about this correctly. Here's what I've done:
Serviced carbs, tested TPS, synced carbs, set idle after setting TPS resistance. Tested temp switch (in case it's in some sort of safe mode), the main oil tank sensor is in the 'up' position (not sure if this sensor has something to do with not getting to higher rpms). I've changed the ignition coil ends (after seeing the wet plugs thinking is an ignition problem) and cleaned fuel filter. The O-rings on a few of the fuel enrichment solenoid were worn or damaged and I replaced them. What I'm going to do (after getting same results) is replace all 3 fuel pumps (as I was getting heavy smoke @ idle), replace the rectifier (as tach not working and getting a parasitic battery drain although the motor is generating good voltage 13.4-14v) and service the carbs again. Also going to clean out the fuel tank and replace fuel lines as the primer bulb does take awhile to get hard (maybe linked to the LPFP). Is there anything I'm missing or what advice do you all have? I have a sense of humor so let me have all suggestions. I've had three different technicians check this out, spent a lot of money and after getting the same result, here I am trying to fix this myself. One of the guys changed a coil under the flywheel (it looked like the smaller 'stator' coil but I don't know anything about these coils). I want to do some fishing ASAP! Thanks in advance for any suggestions and I wanted to be detailed, not lengthy.
Regards,
Watkin
Regards,
Watkin
