Re: 9.9 yamaha case corrosion?
Thank you! I was thinking about a manual also. does it have to fully come apart? Ive tried to find info online about doing it but no luck.
By the way, you have that top plug, where does it drain?
Thanks again!
You can probably just leave the hole without repairing it and it will run fine.
You may see some exhaust escaping through the crack but that area is not essential for proper operation
You can have a welder weld a patch over the crack to hide it without any disassembly. The drawback is that you will still have the salt build up in there
Here's some of the old parts that were replaced prior(4 yrs) to this happening to help you visualize what will be involved. The parts may look different from your since this is a 1988 model
The powerhead(not pictured), base plate and oil tank will lift out as a unit from the mid section case
You will be unplugging some of the electrical plugs, battery cables, fuel line, hoses, throttle and shift linkage
Port view
I'm guessing that you have some salt crystals built up around your tank so it may take some persuasion
to get it apart.
At this point, you can clean the salt off and have a welder patch it up
The top plug is a 3/8" tapered pipe thread brass fitting and a separate plug. I tapped the case for the fitting.
The purpose of it is to be able to squirt freshwater around the oil tank after saltwater use
That water drains down to the exhaust/prop area
Hope this helps
Scott
