Im pretty close to my wits end, I have a current issue with only 1 bank fire-ing in another post. Ive had the boat for only 2 months and i realized that my buzzer wasnt working, which from what im told is a necessity to have to diagnose issues. So i thought ide work form square one then trouble shoot my other issue some more. So I replace the buzzer with a 12v pizzo speaker from radio shack(2 wires on the ignition switch/relay), the old one was the diameter of a lime and all corroded. So I hook the new guy to the wires and there is a constant faint beep/buzz. Now since ive never had the buzzer working on this boat before i thought maybe that was the system telling me the keys were in the on position but it doesn't stop going once the motor is running. Now if I short the temp sensor on the one of the heads its very loud.
I was under the impression that the pizzo is only suppose to beep for like a second once the key is turned to the on position. Does this mean I have a weak short somewhere, or is this working correctly? Engine is a 97 Yamaha 130 SWS, boat is a Cobia 206 Deck Boat(97)
