anderso8623
- May 25, 2012
- 388
I have a 2003 Yamaha 50hp 4 stroke F50TLRB. I was wondering if this motor had a mechanical spark advance. I am used to old 2 strokes where an advance lever was needed to Advance the spark at higher RPM.
Why?
I am having an issue with acceleration. Right around 1800-2000 RPM where my motor will bog down and die. I can typically get it past that RPM fast enough and then it runs fine from 2500- WOT. I have rebuilt the carbs completely. I have done a full tune up including spark plugs. It idles great right at 800 RPM.
My thought with spark advance, if mechanical, it may be sticking and needs to be greased. This was a routine maintenance procedure with my old 2 strokes.
if this is a different issue, please enlighten me.
Why?
