Power Trim
Garfield411
While running at high speed, engine bogs down when using power trim. Anyone have any Idea what is causing that to happen>Engine is. A 2010 Yamaha 200
alldodge
In most cases its caused by corrosion, can also be by a weak battery. Check your connections and load test the battery
