Welcome Guest - Sign Up today
Private Messages
We are aware of a current issue where your messages screen does not properly load and we are working on a fix.
In the interim, you can access you messages by navigating to this link: https://forums.iboats.com/privatemessage/notification
Apologies for the inconvenience.
See more
See less
200 Yahama HPDI Issues - Need Help
  • 200 Yahama HPDI Issues - Need Help
    New here. I have a 2006 Yamaha 200 HPDI VZ200TLR. Boat sat all winter without running. Took to the water last weekend and boat surged bad at idle in neutral and in gear. If any throttle was applied the engine died immediately. Took home and drained all fuel, replaced all plugs, filters (except for mystery filters), primer bulb and line going from bulb to 10micron filter. Fired up with muffs in driveway and still surged but then went to idling at 1500 rpm in neutral but clearly running rough. Checked spark and all plugs sparking as they should in neutral and in gear. Took breather cover off and when i touched throttle linkage the sound of engine changed drastically and idled down but still more rough than usual. Don't have a harness but pinned the tps sensor and cannot get a 5v supply voltage reading from it. If you check the output side you can set to .6v and when you open the throttle the switch voltage goes down instead of up. Assuming route cause is supply voltage. Anyone have suggestions on how to trouble shoot this further?
    Over the winter i installed a couple of new fish finders so i had to run cables inside the boat. Is there anything that i could have unplugged on the boat side of things that would contribute to this? I am assuming the voltage to this switch would be 100% controlled by the ecm.
    Any suggestions welcome.
    Dug deeper today. All “pink wire” sensors are getting their 5v source power. What would cause the TPS to be the only sensor not receiving power?
    Thanks
    Murph21
