Stageharbor
- Feb 24, 2019
- 1
I have a 2006 Yamaha f115 that runs pretty well but is leaking oil from the top crankshaft seal and spewing oil from the breather hose. Causing the engine to smoke. I put some key words in the title That I have heard thrown around for attention. Truth is I’m not sure what is going on. Engine has around 800 hours. Oil level is kept between the marks. Engine does do a-lot of idling. I did a cold leak down and all cylinders had less that 5% leakage? Any ideas? Carbon issue? Thanks in advance Brian
