I have a 2013 DF70A Suzuki motor. The motor started skipping the last time we took it out. At high speeds it would skip a few seconds and clear up. Sometimes running smooth for a few minutes. It also has a rough idle.
this is what i have done. Drained gas and fuel vapor separator and chained fuel/water filter. Added fresh fuel and a bottle of Sea Foam. Also check for loose wires and the spark plugs, which look great. None of this has not helped. I thinking something in the firing. Any suggestions would be greatly appreciated.
