AquaGary
- Dec 21, 2018
- 3
I have 1987 Yamaha 2 stroke 90, on a 1988 24" sun tracker party barge that i have totally restored.. the boat is currently in storage. I ran into an issue late in the season.with this outboard. I put this engine on at the beginning of the season and it ran great. Then the issue started the engine will start and Idle fine I have very long no wake about 20 minutes.
after I get to the open water and apply full throttle. the boat picks up fine for about 2 minutes and then loses power. this is so bad that I barely made it back to the dock. I'm an avid boater , using our boats every weekend.
1) the water pump seems fine the engine is peeing a very solid stream. and does not feel hot to the touch.
2) I replace the spark plugs I thought may be a fouled plugs and same issue.
3) replaced the fuel line bulb and filter. same issue.
4) check the fuel for water contamination, no water. and seems clean.
In the spring I plan on running a compression check, clean the carbs and may be replacing the fuel pump.
I have a couple of questions:
I read that that this engine, has limp mode for the low oil in the injection tank. ( I think this may be what's happening) I don't have a light for it , but it is full of oil. .
1) can the limp mode be disable? I would prefer to run premix anyway since the oil tank access is difficult
2) is this possibly ignition system problem.? I don't know much about how they work.
3) fuel pump may be?
I hoping some one here who has more experience with these outboards may have an idea on what this issue is?
I know much more about i/os my Chevy powered Chris craft is always very reliable.
I've had good luck with my mariner 40 that was on the pontoon boat (which was also a Yamaha) That's why I bought this 90.
I have order the service manual for this engine
Any thoughts you guys may have
thanks in advance
Gary
thanks in advance
Gary
