5150abf
- Aug 12, 2007
- 5,808
2018 F50 on a 16' aluminum V-hull.
Mounted the engine in the middle hole got 5800 rpm, have since moved it to the bottom hole, so all the way up, rpm, went to 6200+ and climbing when I backed off the throttle but still doesn't blow out.
I need to drop at least 500 rpm, currently running a 11x11 so I want a 13x11 now yes?
Enginespert at work told me every inch of pith drops 250rpm, is that correct?
