1999 115 HP 4 stroke Yamaha
medium cool
I need to check my oil gauge, the gauge isn't working, anyone here coach me through that, thanks
medium cool
The boat was re powered with the 4 stroke, it was existing on the center console, maybe I do not need it??Is there no oil pressure gauge on 4 strokes?
99yam40
2 stokes had oil level , so that is why I was asking what gauge you have.
did it have a 4 stroke on it before?
you can rig up all sorts of things if you want to
medium cool
No, it had a Mercury 2 stroke I believe. Do the 4 strokes not have a oil pressure, oil level gauge? I know they have an oil pump that goes bad from time to time, and that if the oil goes down to a specific lower level, it will shut the engine down, as most engines will. But I am curious if the gauge should work or not. I am thinking about putting a new gas "sending unit " for a more accurate gauge of fuel useage, I would use the same hole on the console, it I do not need the oil gauge
tommarvin
Ensign
We have twin 115hp Mercury four stroke EFI no oil pressure and never heard of it on a four stroke.
Maybe on an I/O.
You need to pull the dipstick to check the 100% synthetic stock marine engine oil
A accurate gas gauge and fuel useage sounds like a good thing.
