This one was splined much like a Mercury or Force motor. The speedo hose gets popped off a nipple then the shift shaft will slide out of the upper shaft. be careful it will try to bring the upper shaft with it. If it does just slide it back in, it will only drop in in the right spot, same with the lower, the spline has a flat spot on it, so it will only drop in at one spot.
