I have a dt55 that will start with one fuel pump but wouldnt run.had a spare pump and I put that on and it will run perfect but if you let it sit a day it won't start unless you put the other fuel pump back on .
I took the pump that will start it apart and it had a tear in the diaphram and a spring inside. I took the other pump apart and there is no spring and the diaphram is like a harder plastic.
I ordered a repair kit but it looks like it's hard plastic.
Is there different diaphrams for different years ?
Anyone ever have problem like this?
I'll post pictures tomorrow .
