I have two 1997 Yamaha SW Series 200 hp on my Grady Sailfish. Both engines run great, recently replaced thermostats, spark plugs, water pump impellers this season. Problem with port engine - starts fine but oil alarm goes off and shuts engine down in idle periodically. I check oil tanks and the levels are fine, burns normal amount of oil, no smoke no overheat and water from pump is strong.
Need help diagnosing issue.
