Captain_Crunch
- Jul 18, 2015
- 17
New guy with a used boat needs help! (what a suprise) Vessel has a 1996 Volvo Penta 5.0 with SX outdrive
Hello friends, I have recently become a member of the new used boat club. I purchased a 1996 Chaparral 2130 Sport with a 5.0 Volvo Penta with SX outdrive. I'm about as new to boating as they come, my knowledge is only that of what I have read in forums and watched on YouTube, but I love this stuff and can't wait to get rolling on this continuous project. Disclaimer: I will ask tons of questions some of which may sound dumb but I'm hoping my knowledge gained here from you fine folks will allow me to pass information on to others in my same situation for years to come.
Okay let’s get to the nitty gritty:
1) When I place the boat into gear the engine revs up and down ever so slightly, almost like I'm taping the gas and letting off then tapping the gas and letting off ect. When I give it more gas and get the rpm's up it stops. This engine has electronic fuel injection (you probably already knew that.) I threw some fuel injector cleaner in the gas tank (why the hell not?) that obviously won’t fix it, I just wanted clean insides.
2) This could coincide with number 1, but it is very difficult to put the boat in gear, I really have to muscle the throttle forward, the gears don't grind when I do this, and once in gear, it is difficult to get it back into neutral.
3) This thing seems to be belting out quite a bit of exhaust, not an obnoxious amount by any means but enough to leave a residue on top of the water and stink up the whole boat.
4) The only gauges that work on this baby are the rpm’s and oil pressure (which hovers around 70 psi) all the rest, including the engine temp gauge don’t work (I know that’s an important one as to not blow up my engine) The speedometer hose is sheared right off so I know what’s going on there, but as for the rest…not much clue. With the trim gauge is it the Trim Senders that send the signal to the gauge? It’s possible the wires on those could be corroded.
Lastly, which repair manual would you recommend for this engine and out drive combo, I have going here?
Thanks in advance for any help,
Mike
Mike
