Fishermark
- Oct 19, 2003
- 5,617
This is the 1990 Glastron project boat I am working on. It has a SP-A outdrive. I am trying to remove the lower unit. There are sever allen bolts that need to be removed. (Or at least 7 that I have found - hopefully that is all!)
It took some heat, but six loosened up. The seventh stripped. Not the threads - the top of the bolt where the allen wrench fits. I haven't decided yet what to do. Any suggestions? Because of its location, there is no good way to access it. I think what I am going to try first is to weld the allen wrench in the bolt head. That will allow me to try and turn it. If I get it loose enough I can then cut the allen wrench off and use a wrench on the stub of the allen wrench. The problem is there is not much of the bolt head to weld to.
The other option is to use a cutoff wheel and cut about where the red line is in the picture below. Cut in deep enough to remove the head of the bolt. The lower unit should then come off and I will still have a little stub that I can weld a nut to in order to remove the remainder of the bolt.
Any other ideas?
I will post the results!
Any other ideas?
