First off, love all the info in these forums and could not find anything as specific as my issue below. I just bought a 1998 Regal with a Volvo Penta 4.3L GL. I am having issues getting the starter motor to engage and turn. When I turn the ignition key, I can hear the fuel pump engage. I used a voltmeter to confirm that 12V is getting to the starter relay and that it is being passed down to the starter solenoid (I did order and replace the relay just to make sure it was good as it wasn't making a solid click initially, but felt like it was vibrating some). I've checked the starter solenoid terminals and I'm getting 12V when key on on the red/yellow wire. I have 12V from red Batt+ on the solenoid post all the time. I temporarily jumped the red Batt+ over to the black wire terminal that feeds the starter motor wiring and the starter did spin up. I'm suspicious that my starter solenoid might be bad as I never hear it engage the starter motor gear in the engine flywheel. The other thing I'm not sure how to diagnose is the purple wire on the terminal across from the red/yellow ignition wire. I've read online that the purple wire is a resistor wire for the starter solenoid but I have no idea where it goes and I don't know how to troubleshoot it (what voltages to expect on that terminal during starting).
One final comment that could be related, when I had the boat out last week, I tried to start it over and over for about 1 hour including jumping the battery thinking it might be dead. After letting it sit a while, it finally did start and once it started and was running, it continued to start without any further issues once we were on the water. However, the ignition key off would not kill the engine. I had to pull the emergency kill switch out to get the engine to kill each time we stopped it. I trailered the boat home and when I went out the next day, it was back to not starting at all and I've not been able to get the starter to turn over at all via the key switch since.
Any ideas or help you could give me would be a huge help!
