Welcome Guest - Sign Up today
No announcement yet.
Milky oil in brand new motor!
  • Milky oil in brand new motor!
    First of all, RIP Don S. you helped me through many sleepless nights, thank you for your help and wisdom.
    I have a brand new long-block Volvo Penta 3.0GS with a new exhaust manifold (water pump, carb, starter, alternator are off of old blown motor).
    I put the new motor in the boat, ran it for 10 hours following manufacturer's specs exactly (low RPM's varying speeds, etc.). I really babied this thing. She ran like a top the whole time between 150 and 175 degrees. I kept my eye on the temp sensor constantly as the old motor blew due to an overheat. Never went over 175.
    After 10 hours, I changed the oil and oil filter (the oil I took out looked normal) and took her out on the river for about 5 hours. I opened her up for a couple minutes a few times but mostly kept at no wake speed. Never went over 175 degrees. I checked the oil the next day and it looked like a dirty vanilla shake!! It doesn't seem like much additional liquid is in the motor as the dipstick is still right at the "full" line like when I changed the oil.
    I am at my wits end! I have NO idea what could have happened. My pocketbook and sanity can't take another blown motor!
    Any ideas what it could be?
    I have one (desperate) hope that maybe some water came in somehow when I washed the boat after changing the oil as a lot of water got in the bilge. Seems weird that the oil is that discolored though. Anyone have any thoughts? Thanks for any help!Click image for larger version
    Re: Milky oil in brand new motor!
    I really feel sorry for you, I have to ask if you re-used the cylinder head and if so was it inspected for cracks and flatness before assembly?
    Not many places that water can leak into the motor, cylinder head gasket, riser to manifold gasket, but it has to pass the pistons and you say she ran well, which makes that unlikely. Best of luck, but get the contaminated oil out before it starts to rust things.
    Cranchi Ellipse 21
    5.0Gi (PWTR) 1999.
    DP-SM outdrive
    • #3
      New manifolds risers? New gaskets between the risers/manifolds?
      1998 Wellcraft Eclipse 24 Cuddy
      Volvo Penta Duo-Prop 7.4L "LK"
      2006 Sun Tracker Party Barge 21
      Mercury 90 4-Stroke FI
      "Common sense is not very common"
      "Failing to prepare is preparing to fail." -- John Wooden
      • #4
        Dypcdiver: cylinder head came attached to the new motor. Bruce58: new exhaust manifold, new gasket. Thanks guys, keep the ideas coming!
        • #5
          Water in the bilge that could have possibly reached the crankshaft seal level?
          Might need to do a pressure test on the coolant passages next.
          • #6
            Saw an intake crack one time. It let water into the oil. Only had it happen onece,never saw it happen to anyone else.Owner had us install a new long block,new exhaust/risers,but intake was the issue all along. Just something to check.
            Grub
            If ya can't fix it with a hammer,ya got yourself an electrical problem.
            • #7
              Grub
              Do 3.0s have water going through their intake manifolds? I have never taken one apart so I don't know.
              • #8
                Ahhh... Sorry,I was thinking about a v-8when I wrote that,not shur on the 3.0
                Grub
                • #9
                  I was reading too fast and missed the "Long Block", clutching at straws here, but is there a requirement to re torque cylinder head bolts after the motor has run for a while?
                  Cranchi Ellipse 21
                  5.0Gi (PWTR) 1999.
                  DP-SM outdrive
                  • #10
                    Would you happen to have an oil cooler on it? Some have it some don't.
                    • #11
                      Thanks for the replies, guys. No oil cooler on it. I have re-torqued the bolts as it is a requirement with the new motor (good call). The 3.0 has an combination exhaust/water manifold. Thanks again!
                      • #12
                        Originally posted by robbyr1 View Post
                        Thanks for the replies, guys. No oil cooler on it. I have re-torqued the bolts as it is a requirement with the new motor (good call). The 3.0 has an combination exhaust/water manifold. One thing I saw yesterday while googling my problem was someone saying water can come in through the exhaust if you launch too fast, stop too fast after going WOT or if the back of the boat dips. I did try and go from idle to WOT one time with 3 big guys in the back of the boat and the bow came up pretty good for a few seconds before I backed off and realized I had too much weight in back. Could this cause water in the oil? Thanks again!
                        That is a possibilty however that water would sit on top of the pistons. It usually causes a hydrolock which is even worse than your issue.
                        It's not impossible that you have a bad block or head, even though it's new. You have a warranty, I would be contacting the seller.
                        • #13
                          Not if the engine stayed running after you did that.
                          • #14
                            Thanks for your continued help, guys. I drained the milky oil and refilled with new. I started it on muffs and ran it for a few minutes, ran fine, never got over 125 degrees. Then I took the spark plugs out one by one and did a compression test, cylinder #1 135, #2 135, #3 140, then I took out the plug for 4, put the tester in and water started shooting out of the cylinder. Checked the oil and it was still milky (maybe a little less so). So I took all the plugs out and poured a 1/2 cup of oil in each cylinder (I think that helps stall any rusting?). And here I am. What do you guys think? I can't thank everyone enough for all the help!
                            • #15
                              Manifold riser connection.
                              OEM manifolds or aftermarket?
