pondsplants
- Dec 3, 2012
- 9
Hello
I have a 2001 Cobalt 226 with volvo penta 5.7 gsi DP and my steering is not smooth. The wheel jerks at several spots on rotation. I have read many threads and decided to swap out the power steering pump. This didn't help. So, I read some more and decided to r/r the steering cable. This made no improvement either.
All that is left to change is the steering actuator, the pinion gear at the helm (which seemed to spin freely when I removed the rack) or maybe the pivot points on the outdrive??
How do I know if the actuator is bad. It doesn't appear to be leaking fluid. It does move around a lot when you move the wheel, but I think that is normal? How would I know if the pivot points on the outdrive are binding?
Thank you in advance for any assistance.
Chris
Chris
