Engine SN 4012113432
On start up, turning the key to ON, the fuel pump sometimes does not turn on for the usual aproximate 3 seconds.
All fuses in the Fuse/ Relay box are fine, I replaced the Fuel Pump Relay and the Ignition Relay - problem persists.
With key in the ON position, there was no power to the LP fuel pump terminal. I did not check the HP terminal.
Engine cranks, but will not start.
Now that I think about it, the fuel pump wind-up is probably the HP pump. I will check for power at the HP terminal in the morning.
Is there anything else that could be causing the intermitant problem.
Thanks
Thanks
