Welcome Guest - Sign Up today
No announcement yet.
Aq280 install - stuck with an inch to go!
This topic is closed.
  • Aq280 install - stuck with an inch to go!
    I'm in the middle of installing my Volvo aq280 leg to my aq 260 5.7 l, but the drive is stuck about an inch (maybe less) from the yoke pins. I've tried a mallet, I've tried jiggling it, and I've tried steady pressure, but it will not bUdge. It also does not want to come back off. Any help would be appreciated.
    Re: Aq280 install - stuck with an inch to go!
    Turn the prop with it in gear to line up the splines.
    Cranchi Ellipse 21
    5.0Gi (PWTR) 1999.
    DP-SM outdrive
    • #3
      Splines are aligned. As I said, it only as 1 inch to go - the splines were aligned 3 inches ago.
      Thx.
      • #4
        I guess the next step is to attemp removal, and try filing the splines for a better fit?
        • #5
          IMHO, it's much easier to install the outdrive without the upper gearbox attached to the intermediate. Then you can install the gearbox by itself. If you do it that way, you're more likely to easier see any interferience without wrestling with multiple issues.
          '76 Fiberform Custom 18
          Volvo AQ130D/280
          • #6
            Thanks. I had not thought of that. I'll give it a shot.
            • #7
              No dice. Got the upper disconnected from the drive, but the ujoint yoke is stuck fast. Won't budge in or out.
              • #8
                Ouch.... rubber mallet or pry it off. I've heard of people using a come-along if needed.
                Volvo AQ130D/280
                • #9
                  Mallet and webbing come-a-long did not work. I'll be disassembling the u joints and trying a three jaw puller next.
                  • #10
                    Sounds rough. Are the shaft and yoke the original ones?
                    Volvo AQ130D/280
                    • #11
                      Probably. Interesting part is that they got stuck on install, not removal (iow they are not rusted together).
                      • #12
                        Did you find out why it got stuck? I took off the upper housing and the yoke slipped out easily. But now putting it back in it doesn't fit. Don't want to bang it in and get it stuck.
                        • #13
                          Please start a new thread. None of members posting in this thread visit anymore and it's over 6 years old. Thanks.
                          Closed.
                          BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
                          Please, no PM's (Private Messages) regarding boat/engine problems.
                          That is what the forums are for.
                          Only forum/moderator issues will be answered in PM's.
