Welcome Guest - Sign Up today
No announcement yet.
Which Fuel Pump Iboats and Volvo have two part numbers for same pump.
  • Which Fuel Pump Iboats and Volvo have two part numbers for same pump.
    There are two pumps listed one for 196 and one for 239.....http://www.volvopentastore.com/Fuel-...-viewcart.long
    I put in both numbers here on Iboats and get two options $168 and $138
    http://www.iboats.com/Boat-Parts-Acc...****.904605835
    http://www.iboats.com/Boat-Parts-Acc....0--submit.y.0
    So since I try to support Iboats which one do I need ??
    This is for the fuel pump just above the fuel filter on the front of the engine. Part #68 from this diagram http://www.volvopentastore.com/Fuel-...view_id.775679
    Current 1995 Carver 250 Express Volvo Penta 5.7GIPMDA DP-C1 drive with a 1.95:1 gear ratio Oftr 18-7876 and 18' Gulfcoast Sailboat (project)
    Past 28' party hut with Johnson 115 and 110 RIP
    Various small boats and outboards generally below 10hp
    Lake Ray Roberts
    Re: Which Fuel Pump Iboats and Volvo have two part numbers for same pump.
    So I have been able to figure out one is for a big block or small block GM the other is for a ford ?
    Lake Ray Roberts
    • #3
      If you use the parts diagram, you will notice there is a 1 and 2 at the end of the part numbers. You need to read the notes at the bottom of the parts list. It tells you which one you need.
      Don S.
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        Here is a pic just my luck it does not have part # in picture.....back to the lake I guess....
        Lake Ray Roberts
        • #5
          ahhhhh so I would assume a big block is anything over 400 ? and I have the small block ??.....figures the more expensive of the two options )(*#@-)@(#8(#%$
          Lake Ray Roberts
