Welcome Guest - Sign Up today
  • Dear Community Members,
    Over the last two years, there have been updates to the environment that have introduced challenges in usability, performance, and security. Efforts to improve the technology, user interface and site performance have revealed weaknesses in the platform and outdated software our site uses. This has made it increasingly difficult and frustrating to support and upgrade to more modern reliable standards that users deserve. This is not the experience we want for the members of this community.
    Members want a fast site that performs well across all devices, to be able to find relevant and interesting content, and easily share through text, images, video, and messaging on a secure platform. Our goal is to provide this user experience to all members. We will be updating to a new platform to better meet the needs of this community and allow us to provide support more efficiently. Our focus is to create a sustainable platform that performs well and loads faster on all devices while offering seamless ways to search and connect. Technology is constantly innovating - by creating an environment that we control we can maintain the site with more frequent improvements and maintenance updates.
    Although change can be difficult, we are here to support you through the process. We make every effort to review existing settings and make the changes needed so the migration goes smoothly. If you notice something doesn’t seem correct once the site goes live, don’t panic! We’ll have a dedicated person monitoring as the site goes live to answer any questions and provide support through this change. What’s next?
    When will this be happening? The plan is to put our current forums into maintenance mode (off line) at around 9am MST on 9/30/2020! The whole transition should take 24-36 hours. We recognize the user experience is slow and there are bugs from the outdated software. The sooner we can change that the better we can make the experience for you. You’ll start to see activity related to cleanup in preparation for migration very shortly. We will post an announcement to the community prior to starting the actual data migration.
    We appreciate each member’s contribution to this community and look forward to an improved experience for you all.
    - Management
No announcement yet.
Volvo/Penta trim won't go down!
  • Volvo/Penta trim won't go down!
    2001 Glastron 175 SX, 3.0L Volvo (GM), SX drive
    Parked the boat last October and everything was working just fine. Got the boat out this weekend to clean up and get ready for the season, charged battery to full (13.5 v), added fresh gas and the engine fired right up. Tried to trim down and it won't budge. Up works, but now its trimmed up as far as it will go and it won't trim down. When I press the switch I can hear a "click" from the relay, but the pump motor won't run when trying to trim down. Works like normal on trim up. Fluid reservoir is about 1/2 full, but I don't see any marks on the reservoir to indicate where "full" should be. I'm assuming the trim pump is ok since it runs fine on trim up. I also assume the relay is working because I can hear it click when I press the trim down switch on the control. And I can assume the switch is working ok since trim up works and I hear the click at the relay on trim down. Should I not assume these things? What should I do? What should I be looking at to fix this issue?
    Thanks for any help or advice!
    Re: Volvo/Penta trim won't go down!
    Ayuh,... I assume there's Corroded wiring connections, causing the problem...
    Remove, sand, clean,+ reconnect everything...
    • #3
      Flip flop the two relays and see if it goes down
      If you can read this thank a teacher.If you can read it in english THANK A VETERAN
      • #4
        (solenoids)
        the fluid can only be checked in lowered position.
        id rather be fishing in a ugly boat than working on a pretty one!!!
        1969 starcraft v-180 120 merc i/o
        1975 starcraft 18ss i/o awaiting resurection
        • #5
          I second Bond-o.
          Had a similar issue last year, and eliminated it by cleaning all the connections, which seems to cure about 90% of the electrical issues I run into on my older boat- I usually start there now and have saved a lot of time.... Most of the other 10% of problems are wire related...
          -Bill R.
          1981 Albemarle 24' cuddy
          Volvo AQ271C
          • #6
            Originally posted by cedarjunki View Post
            (solenoids)
            There are no solenoids in Volvo trim systems, they use relays, and low oil would not prevent the motor from running.
            I would pull the relays and check the connections for corrosion. If they are clean, you probably have a bad relay. Yes, they can click and still not work.
            It also takes both relays to go either up or down. Below is a wiring diagram to help you figure it out. You can pull the relays out and check the sockets with a test light or meter. If they test OK, they you probably need a relay.
            PS Green = down, blue = up
            Don S.
            Please, no PM's (Private Messages) regarding boat/engine problems.
            That is what the forums are for.
            Only forum/moderator issues will be answered in PM's.
            • #7
              i learn something new everyday!
              • #8
                Thanks for all the info, fellas! I will check the connections and test the relays as soon as the rain stops. I'll let you know what I find.
                • #9
                  Had the same problem 2 months ago with starboard drive. Tech swapped the relays and tested the connections. All OK but he found that one of the harness connectors moved out of place during the connect enough to cause the problem. Tried to reseat & secure the pin but it happened a few weeks later. I got a used harness & replaced it with no problems to date.
                  • #10
                    I finally had a chance to look at it today. I pulled both relays and swapped them in the sockets, and now I have down trim but not up....... which tells me the relay is kaput. The relay is made by Hella, the local boat shop wants $30 for a new one. Is this relay any different than an automotive relay? Is it sealed or something different for marine use? Because I can get a replacement @ Kragen or Napa for about $7.
                    • #11
                      Just make sure the contacts have the proper amperage ratings. Should be on one of your old relays, and I don't recall what it is right off. But it will take a relay with all 5 terminals on it. Many only have 4.
                      Don S.
                      • #12
                        The part number on the relay is 4RD 931 680-01. This is the German Hella part number. I cross reference that number to Hella USA's number which is HL87429, but none of the parts supply places in town seem to be able to cross reference it to anything. Its a 5-pin, 12 volt, hi-temp, potted relay.
                        • #13
                          Volvo only uses Bosch relays. Maybe someone has replaced it with the wrong kind and that is why you have a problem now.
                          Don S.
                          • #14
                            Nope, I bought this boat brand new off the Glastron showroom in 2001, I'm the only owner, and I've never replaced any relays. The Hella relays that are in it came from the factory.
                            • #15
                              Bought a relay this afternoon from a local parts supplier, its not a Hella but its the same relay-- 5 pin with the same schematic. As I said before, the local boat shop wanted $30 for the factory replacement "because its waterproofed". Welp, I bought a replacement for $7, spent another $2.50 on some flowable silicone sealant, and waterproofed it myself. Works like a champ and spent less than $10.
                              Thanks for all the help fellas!
