I have a 1996 Volvo Penta 4.3 w/ a holley 2bbl carb on it. Last week took the boat out and ran it for about 4 hours. Ran perfect. Thursday took it back out and would not start. After several hours of trouble shooting it I found out that there is absolutely no gas getting to the carburetor. Thinking it was a clog I started at the gas tank and worked my way up to the carb. Checked all lines for cracks, and checked for any interference in the lines, but there were none. I am getting power to the fuel pump when turning it over I also noticed that the accelerator pump is not priming at all. I have to pour gas in the top of the carb for it to fire, but it only burns the fuel off then stalls!!! I bought a new fuel filter but no help.
When I was looking for clogs in the line I tried to blow thru the fuel pump and it is very hard to do so. Is this normal?
what could cause my carb bowl to become empty? I do not smell or see any gas leaks after I pour it down the throat of the carb? I would have thought that after I prime it and it started the motor that the fuel pump would then pull gas into the carb? But I do not think that is happening? Any ideas I am absolutely stumped!! Thanks very much for any replys in advance.
Thanks again
Frustrated boat owner
Thanks again
