Welcome Guest - Sign Up today
No announcement yet.
Volvo / Sherwood impeller kit... HELP
  • Volvo / Sherwood impeller kit... HELP
    Hello all: I have a sheerwood sea water pump I want to replace the impeller and gaskets in but am having a hell of a time finding the kit for the specific pump. I can find impeller but not kit.
    I have went to volvo site with no luck. I keep getting kits that the gaskets are not even close to.
    Through extensive research I believe this is a Sherwood G9901 pump as it has the 6 1/2 pully as shown in this link.
    http://www.marinemanifold.com/partsp...NES/VOLVO1.HTM
    I have uploaded a picture of the pump pulled apart
    Anybody have a kit # for this pump? I do not care who the manufacturer is I just want the proper kit.
    Thanks in advance
    Re: Volvo / Sherwood impeller kit... HELP
    If no luck in the Iboats store try Ebasicpower on the web, pretty sure they have one..
    1981 ChrisCraft 210 Scorpion K,175 Johnson SeaHorse
    • #3
      What is the FULL model number of your engine?
      Don S.
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        Hi Don: The complete model number is 5.7 GL PMDA
        I ended up finding the kit from Sherwood. It is the 9959K. The corresponding volvo / aftermarket kits did not contain the o-ring or the proper gaskets in their kits. For example the Sierra 18-3046 kit.
        I found the prints for the pump
        http://www.sherwoodpumpsdistribution.../MPG_G9901.pdf
        And also the kit specs and got the machinist ruler out and match everything up to be sure.
        Also happened to find a Sherwood G9001 new pump in my searching for only $101.
        Don would you know the tourque setting for the manifold and riser bolts on the 5.7 GL? I suck up sand and had to pull to clean them out.
        As always Don, your help is greatly appreciated.
