Volym
- Apr 8, 2020
- 10
Hey boaters! I have a problem with my Four Winns 268 vista that is keeping me up at night. The boat was working fine when I used it the last time. But now when I was trying to get out on the waters again the boat was fighting me in the marina. I put the ignition on and put it to stage one, Then the outdrive was trying to raise itself up all the time with out pushing the leaver. I unplugged the batteries and put a dehumidifier in the engine compartment. Got back the next day and the problem had got away. Now to the main problem.
The engine wonāt start!! The fuel pumps donāt prime but the pumps are working if I bypass the relay with a wire. But the injectors wonāt spray. I tested the injectors with a 9v battery and they spray fine when I bypass the relay. I have spark and oil pressure. The water temp fluctuate from low to max, The tachometer comes and goes, But do not show rpm when I crank the engine. Same when I removed the grey wire. The relays seems to be okay when I test them. What is the next step to go for? Sorry for my English not my first language āSwedishā
Engine serial number : 5.7 gsi PWRT ā3868947ā
