Welcome Guest - Sign Up today
No announcement yet.
Coupler Help Needed
  • Coupler Help Needed
    talking about couplers! I recently bought a 1986 bayliner capri cuddy 5.0 without an engine and it had the outdrive that is a volvo penta 275 at low price and a automotive mechanic friend told me about a mercruise 5.7 engine that was also selling at a good price and the block was similar to the supposed engine that I had it before (5.0) so I took the opportunity. When trying to install it, the coupler did not assemble,I order another one with the info I had and also don't assemble, I am new to all this and I have been trying to find it but with so much info it is very confusing at the same time but I will not give up, the next step that we did is count the splines and measure the shaft diameter (26 splines, 1 1/4 diam) and what I found with the info of the outdrive and 26 splines Engine Vibration Dampener couplers at this point I am confused if someone can guide me or maybe the Question is if the engine is compatible with the outdrive as my friend says, or how to know exactly what is the original boat engine etc ... if someone can guide me I would appreciate it!
    Volvo and Merc use the same base engine from GM, but that's where the similarity ends.
    They use their own transom assemblies and drives, and they're not interchangeable/compatible in any way. Even the fuel, ignition, cooling and exhaust systems are completely different ..
    Chris...
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    The world takes on a whole new perspective when viewed from 100’ below.
    1972 Bertram ‘Bahia Mar’ 20
    2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
    (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
    • #3
      The 80's Volvo used a light duty block and crank.
      It needed a special flywheel to have the crank work.
      The coupler is way different to.
      The coupler #14 (pic #2)is what you need for the
      Volvo. Mercruiser(pic #1) is way different.
      The block itself will probably match the bellhousing but that's probably the only thing that will??
      [IMG]https://forums.iboats.com/core/image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAIIAAACCCAMAAAC 93eDPAAAAIVBMVEUBBgQDBwMcFAEeFwEEBgNHcEwICQIXEAIOD AIWEgEeFwOdvLkgAAAAC3RSTlPYyFhjugCoSJJ5J eQCkMAAAwTSURBVHictZwHguQoDEWNoQi /4FXCZEN7t11z0xXNI8voYCr5vr97XieJ8Bx37fF477xHjz4h1N dfxnb8rA48m3xD93JB6D8fwgw j05GOC2wSb4FfjeOcc5Agw/BbhZBmufX/I hl9QsDOKQwScfiDjh3rk6pZNKXrvACLq42cUJwg4fxkfEWoMq7 S89E74wEjNkbaWmSL8PDgaNwgBPegBdohEgKC4Pq49SVbKd4Rn ofm/7MwOfvjO2X4UEPgWGCJmGz7NN21bxBvCCxASDEaOGCGsZx75Zn 6ilYp wKxRhCAcHvj3AUIwHCHwRvG4fVoXrU2xxKhnAkQjLkQIpXp2Wo 93BQlWZw88kCJMesTwhOqyYCNnXMRAXhVkI/hE9aClZJ98MgeGDKmMth3iDlC6I7q1AIAqj4wPDgguKA4fZDpI 5t6pURyK7cPEZ6eIKjA4ebMcMNaiXiAPrAKICxF0CLrcCdrKwl keA6io0dMEEaCoF4YiAD1T6RBpHhIt2NZkCRDsiyBMPPKhccHh hFhQkCDsxFQYQDIwyKCYxXQKElHSzmZVjlU8lnPMCAIwQDCLka nwmwUZeKoggdN4Cb6ReJYSf gDjYHhYTPQXDDt28QKoKnGz/wGkANfKUCWYJvYwytjC9GQN9MGFV8kET jqCjPp0GEg5YBB2VlitpAg8xQja Lgh4A2ACAq7siTtcU4JnGJ6FsPg3ifgdAqrgYkawEr1oSINvQL mc47T goCJ6Jn5QUlNcDPiGSMNKghoFVJBVl4OBVzcYfoCQ4AMPtFD8V kj3HNHrLICrYroMgKeGwNnIoKYnaBai0yDiEAqkSLaJcJj7/lyCCIDBT24CbZQMyAC WLUpZ yU1r yb6RtYxxiRBsCHWqKzLwb2s9ZQpc92x90tfALQlL KJkc3Asxij3KWj4JQIW4CHkKKyzZ23oHFiVcUYKUi3S6mDloUR 7gqqQFaiq/bxgk39WCMmSEZ6HogyXTOKDIgOsLfKlR2KETvfmcoB6DEFgh6i ylCaN5FYIT4SJPGgNlBfXHany3AmxyEMi p5liBKCrObhh8TRYFyMcZdf4I5rBI8iJ/IxLJIukx45iIFl8Cmx5Wm mK/4kISdxbE6uC2hSlKIdytfeBwk3BDRwQwVapelLhFHl9BgKUGxL bkhLfgD nAhhAGzdLNAc 4tQomwmStubhQu5xVEbKoOmkck1c7wyRYKWKIogJroDA5c0Szd MfHeXKG6FEErEGekL****I4NiQbEh7twDLQw9RFZgTJT7byhQL hTVyuCIrx6GZ1RKpaEra fVjvm4IeGoKRyEnVPW1JFXetAqwHmN4Sgfw9cXQI5Z1abFge6w 55d8FyriJNgiDclTvKgrQ1goVQ1uSpNjoakwNNvWEwOeR5KRp4 RYRHmv CrLFJx7 xLXkL0OCCUfyLQ0xi985BSMFSsjUC2YfTqHpASRF3uYO CPF8rcLjr4srjzI5nqGsswwgEZAQEsrGz dkJpscDKYRmv5N6OgxrBGSEQRPRZBqXMfiWgWb8vOpBCCZN7gW uurzuxWDNMCk9ntB8CYlXx2VqdWmtU9khFQgNIBAVYGFUkpqGu uZ4K1qgtckd2EhQu/OEEnCvmqgHqJGEpk0JEcq1vCAVlRESNgdYzR7qx3hnRAVL8cQr iihqUdFSOoVylAFIesvKldxIlfkR8EIlyPj/l4QHkCg0CwMCpGyECR9ZYxUNFBD0YzhJI4yDZesRGC44Pu9Ifw SI5BPuqIELzzMyDf2TDdWN8PRhGHoKz2dyye2jWcCOPOmmwruw vfJxhUSOF97RPCRqFIz 0yQiyOB0CwJdYa5MsHQ4PetTEIEMASmSraCK25JpqG/7GMNQDN20B/MXjeeTgQdtxiGhs6TDK5yS12gnibCbZFJnQKNEe4777OA6iFx6 qUzTXZ7xraWTIGlMbPUUQIRqJyB1Z3n3kmgiZW0wPSNDR0TON9 3tHMEcgeeKNnECAUZkmzATjauhNoIMj4okGxkaOp/zxB Ade0LxCihdNDIvd6OVgCgDLUseGMrE5Yn2cIEB0ufoMxGeKSk1 SBu2bglKwEnMfAB404jhDAv/c43HS7K1zs STgVR01R4ypDU3czFGDbWSXkBVgFdga8WivCVemUNO60PH1N8/K8z5XrmaxaPA G8/kw XRxSFGj5wi OwLlQo48NUgkadG/pGooS/W8V2WIj8yyjD3BbZDK4Mp5 Y7pkw1P9QRGCaQV/ADfvDIGYKV8S/TWqI/3Oq51gg1Ke4inyBE3pORaXeecHLUjtA hpsR200/jNHwOpShHfsDQ2We/nE4dZ8lZqEJm o6Mn095uMLgvd9aJggJEiRty8I7a8zhuUT3vdF0xzBOYytf1Vh/TYum/pd6CmCMdiAu EU4yP94BtqRghbBCwz4 13IvRqz81fH543LJPdITwJ61foAjZT7sY0Ly4gwC5ylj1B4Br6 wBUMR1BGeFXBaAV0hCBFG75p65LNsDvTCcJrH4FHsE5kxei2V2 KBMx4pUkV8oEJInt/ith7ZA7y/3EUKCwfueCOC4Sr62/H6 lySR9m3fEOwiODMZwTzzmCkmTlAeLABZkf4KsNmRRi2wwGCRQR OaotssxzltX7IHd0RAkcEKZpi/A8QqDnjTgKjY9gjXBnhWAEZagUg9XTeKDhAUBV2YbeXYQEgBM5 LF3RvEFJjiH8rA26rUK2bOxBUYYMQbOS9idoQk8Q91aB7HbSeV uxaeqADFaAhcqbOQCBlCPYoa0FHXpRwdEEuMpwaYgyPM0PgHku lAiBYC 3yPn3DC5JP/C5v6aqqkZVipL2fBIYFgpOOjs9MEuNVojiVout2LgPRDbs83gc wBSEviR0CXRZ3ubUWO/Jvca2tPZLPgmk1b0pHjJ 22CDQdU/nmjL Nfqvn6aQmENjscSRCt7XKuQZHcWIbjdAmirpL/myZnpH CW 4iQbDO0Zeduuj5puKUXTTGZv2Krwk10KryqY7qzY0TcY65XStb TmE4JaYiH98PA0OLfjiym qeA2dcjL8JUGTv91syp h/A5TcxUKLss/JmPHcKd9KMRoz9 0ODqbaDRaZcjCIE K3TMsCIzwyG7ljuEwB9LEBW J xRBN34E4StCoHDY2WJTXHe/q4Qrs4Rjg2BEVouRdQO bma7sOSBoZtvUARWlWQCP ZQXbrehUEYVM7YiNR8tSBJc5EqFXYdlN4CaOER3bI7z3NEJqr0 HSAYGO7JMxZjOwVuBoJXBbB79vaXLR0pjhlMLJb3flhDtBne01 PFR/NVxl48MmCUBVOdtwkROdF6aTsOQcYj2yMmStMEbIztA65ozC1A gOKzMaNrjC/GHCndknk8m 7DZjDwSw98M8QmBaXRGpLcEuTT8zTXYz/dshFKjd64xzhqfN1luFle7sxhCnAnSEc7XHsPwFMh 0Z1L4vpdxqdC2YKE/2 20rhLuJDEavLtU5Y6LCwhVz2cgI28vmM0u4HGG4OV1BFKnG9SC fp8AFcXR5rLeE0eiQrbqFGBjQE njEIcXCbvopMGtnG5xzWUxvpphcllo/f0I21iiuupqJPCX/sloL1UccmYH/rDwONbqWyJNZ n02m ByGOXfmsmQG09qsQm181XCG3RUNtBZ9qoUPxwviC4anT9R2neE H62avHzmnANg4795oeqAbeTs6/srL u066JAcDkMqIdfuRwKkKc OIbws/2oWEwRjPqiyu43NXPPkDx r2p3hs6iKsy/XpBlhU5XqDcIiBDk6oGd3gfu0CII4xxcYtAn SqY8NEh 34xmVPWGiw RpfZtCax SCdOIXSztsCDbfJLR9wnx3ySkCi7Am2H2f0pZSuizNnmMbF6dB 8RSBbaEByqx1eDNDnHyU6BwBL9iVHjtHyorjNR6QdsulcIqAJX 27KObeOAMg3nlI/IRAlw3VHfPHxXKf oaDT47V6p8QsHooKpTBp6NfHwHOv2dt6dOOrlkXTuRY5A/8Ws3JuY /bf7c0ZfZ5/VRpOggYB2efuP9y3fuUYrKCRazp6uyx N/RPixFr5y XF4 prHp3N /s8PpOud1HKUjz8O/0cEAeHvbsWYP6B8f/1/F/LxD g/4usQzK4kAAAAAElFTkSuQmCC[/IMG]
      Crankshaft And Related Parts: D
      Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
      ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
      In Scenic , Beautiful San Sebastian by the sea Florida
      88 Bayliner 21CC 2001 Mercury 225 HP EFI
      PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
      • #4
        Ayuh,..... Welcome Aboard,...... As achris says,.... Only the basic Long Block, is the same 'tween the original motor, 'n the Merc motor yer tryin' to stuff in there,.....
        All of the stuff bolted to the basic Long Block is different,.....
        If you could find the old motor, you'd be miles ahead, provided the accessory parts are salvageable,.....
        Or,.....
        Find a serviceable copy of the original motor,.....
        'n I think what Jerry is gettin' at is,.....
        The older Volvos ran the 12" flywheel, 'n related parts,....
        Merc has generally always run the 14" flywheel, 'n related parts,.....
        Other than the 3.0ls that used the 12" flywheel,....
        • #5
          Fly wheel off a Camaro.
