bhollehday
- Aug 16, 2017
- 77
I have always noticed a squeal from the belt and started replaced the alternator, idler, tensioner. I put a new belt on too. Now the new belt slips off the water pump pulley by a tooth. I have read that the PS pump is to blame, and it does look about an 1/8” in front of the water pump pulley, but if I move the alternator back, the belt is already on the edge of the idler pulley. Also after looking at the routing it looks like the belt on the water pump pulley would only slip a tooth if the tensioner was too far forward or water pump pulley was too far back. It looks like a need to shim the water pump pulley forward by a little to fix. Can anyone give me some insight here?
Pictures:
https://drive.google.com/drive/folders/1GtwP-jE7ZreTdRLYqT-8VqT0d4Hlxml5?usp=sharing
Pictures:
