harojs
- Aug 28, 2016
- 84
[Q1] Can you grease the gimbal bearing on a 1995 SX via a couple pumps of grease to the Zerc grease fitting on right side of SX without removing drive?
[Q2] When gimbal bearing needs grease, does it give you warning?
I'm hearing a low volume noise that might be the gimbal bearing starting to complain and wondering if a shot of grease will make it happier until I can do a full maintenance on the SX this fall.
