I went over this same issue last year. I bought the Barr Manifolds, Risers, Gaskets and hardware as a kit. They arrived with the sealing surfaces painted as well. After much research and unnecessary agony, I finally came to the conclusion that I needed to use a flat file and slowly knock the paint and high spots off the sealing surfaces. Done properly, you are left with a completely flat manifold surface ready to be mated to the heads and risers to manifolds. Use the supplied gaskets. They are of good quality. Do not trust the green ones that are sold by third parties. They are called green leakers for a reason. Ask me how I know. There is a tech bulletin out from volvo. They now recommend using permatex copper seal-a-gasket on the riser gaskets only. Do not use sealant on the manifold to head gaskets. Those gaskets go on dry. Torque manifold bolts 20-25ft lbs. Riser bolts to 30ft lbs. Make sure you use a cross tightening pattern torquing to half spec on the first pass. Follow up to full spec on the second. Run the engine through several heat cycles and recheck your torque specs on all bolts. Done.
