My 84 Baylinner has a AQ125 with a 270 leg .
On the hand throttle ,as you move it forward about 1/8 -1/4 forward the boat will move forward smoothly up to 3 mph ,we call this 1st gear . When you push the lever forward more you can feel a little click or bump in the hand throttle . I call this second gear.
When the engine is cool . She wants to stall when i go into second, So I will pull back to first so she will run and then I pump the throttle back and forth in and out of 1and 2 till she will run in second.
This boat has been doing this for many years .Not sure if it is fix able .
Not sure if it is under or over fuelling when cold as it has no choke.
Should the cable on the carb be adjusted so it has lower or higher speed when it shifts or is there a cable adjustment for the leg so it shifts higher up.
Is there realy a second gear in the leg or is it just in the throttle box .
