Welcome Guest - Sign Up today
No announcement yet.
Water pump housing
  • Water pump housing
    Pulled my water pump housing to replace my impeller. Noticed some wear grooves in the housing. Should I replace it or leave it alone?
    Chances are that a new impeller will be messed up if you re-use the housing. I would replace it.
    How is the wear plate the other end that the impeller also rides on?
    BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      • #4
        Looks like it’s groved too.
        • #5
          The plate is just as bad. A compete kit is the way to go so the impeller lasts.
          • #6
            Thanks for the input.
