corvettedude
- Apr 30, 2018
- 62
Hey everyone I just finished winterizing my boat today, and something odd happened. I drained my block and manifold then I let in run for about 30 minutes on the muffs and everything was fine thermostat was opening at 180 like always, no problems. So then I shut down the hose and switched to antifreeze. I have one of those 5 gallon jugs with the connections to use a water hose to get it to temp then swap to antifreeze. Anyways when I swapped to antifreeze everything was going good until I had about half a gallon of antifreeze left and I noticed its suddenly quit picking up the stuff then I glanced at my dash and my temp was 200!!! So I just shut it down, then tried again about 5 minutes later and it quickly went to 200 again. I was unable to get it to pick up that last 1/2 gallon. Any input on what my have happened? Big air bubble from when I shut down water until I turned on antifreeze? I did actually walk back and turned off water at the tap not just flipped the switch on the jug. Thermostat? Impeller? both were changed spring of 2015. As far as not getting enough antifreeze into the block i'm not really concerned about because I drain it all back out anyways and fill block with a corrosion resistant antifreeze so it won't rust, but I really don't wanna spend the next 5 months worrying about what happened. Also I think I will check out my impellor one evening this week to see if that could be it. Any input would be appreciated so I don't worry all winter.
