boater535
- Sep 30, 2018
- 7
hey guys i wanted to winterize my boat by myself this year instead of taking it up to the marina and save a couple hundred bucks.. was wondering if I did it right and if I did not or need to do more please comment below!!
1- drained engine blocks, right side and left side, used wire to loosen up any debris or sand at the hole where the plug is
2- drained both exhaust/riser manifolds
3- removed/loosened water pump hoses, both IN and OUT hoses, let water drain completely
4- removed/loosened thermostat hose and let that drain, lifted boat as high as it could go so all water would drain out
5- removed square bolt infront of intake manifold, lowered my trailer as much as possible so water would drain towards bow of boat
6- turned key in ignition to have any remaining water get spit out from water pump, did this three times, I DID NOT START ALL THE WAY, just a small turn and shut off.
7- Put left exhaust/riser drain plug back in, and loosened/removed hose that leads to opposite side of riser near intake manifold and filled with antifreeze - waited for antifreeze to come out of the drain hole in riser then tightened, filled exhaust/riser manifold with a little antifreeze, then put hose back on and tightened clamp
8- Put right exhaust/riser drain plug back in did the same for this side, filled with antifreeze watched it come out then tighten and topped off with more antifreeze and tightened plug.
9- Filled thermostat hose with antifreeze and made sure antifreeze came out of both drain holes in the engine block, then tightened.
10- LOWER UNIT; filled antifreeze in intake hose which is used for garden hose to start without muffs and waited for antifreeze to come out of lower unit.
Thats all i did to winterize my Volvo Penta 4.3GL Engine. Please let me know if I did this right, and if there are any concerns or issues you guys find I would like to hear!! I know you don't have to fill the engine block or manifolds with antifreeze but I did just as a preventative measure.
THANKS IN ADVANCE GUYS!!
