I've got oil leaking from somewhere up high on the engine, I believe on the port side near the transom. The oil is running down the port/stern area of the engine near the serial number plate.
Is there a common spot for a leak in this area? I've read that it's possible to have a leak from the distributor spindle (?) or from the oil pressure sender port.
Any advice to track this down would be appreciated. Thank you.
