USA_boater
- Jul 31, 2018
- 275
Boat sat for 5 yrs before I bought it (has 4.3 GL-C). If it idles on trailer it will not overheat but will go up 3/4 temp gauge...taking RPMs up a bit will drop temp to just above half but not ever run below half once warmed up. I changed the impeller today and found it did have one torn vain missing about half of it; the rest were brittle but intact. After changing impeller, the temp gauge behaves the SAME with the new impeller (on trailer).
So next i took off the t-stat housing and found tons of rust/flakes in the intake and in the hoses and the t-stat was full of buildup and rust. I ordered the wrong t-stat kit so I have to re-order and while I'm waiting, I'm going to scrape loose the scale in the intake through the t-stat hole and then shop vac it out. I am also going to loosen the rust in the hoses and shop vac those too and then maybe replace the circulation pump hose that is sorta brittle and has lots of rusty buildup in it. I'll then clean the t-state housing inside with scotch brite, wire brush and WD40 and then get it as clean as I can where I can reach inside it.
BUT I do have a spare gasket and wondered if I could run it to flush the trash with no t-stat installed and also see if it heats up the same or if it is any better running with no t-stat. Can I do this and what else should I be doing to try and make sure this boat is lake-ready as far as the temp issue???
I already changed the oil and filter and fuel filter and poured seafoam in the gas...the boat HAS RUN on water twice since I got it; it was the second time out for testing that I noticed the temp creeping up so it prompted my actions I had already planned to do to come sooner rather than later.
