so today I had a planned fishing trip.. drop the boat in fire it up with a bump of the key and all is well.. I start to motor out just in gear.. maybe 5 knots and I see the temp climb... gets a lil got so I shut it down and drop anchor
while it’s cooling down I pull the brand new impeller.. looks great.. no leaks. Good o ring.. and the new bearing spins.. the housing is also new and free of grooves..
i fire it back up and the temp climbs at idle so I shut it down and call a tow...
back at the house I replace the thermostat o ring and gasket.. I also pull the drive and inspect the hose and plastic fitting that the h20 is pulled from...
i pulled the intake hose to the impeller and back flowed with a hose and water flowed out the drive.
With the hoses off the manifolds I start it on the hose... a few min pass and h20 flows out both hoses.. I shut it down. Connected the hoses to the manifolds and fired it...
ran for 25 min at idle on the hose and the temp is solid at 170
take it back to the bay and before I can get it to the dock the temp climbs.. I shut it down.. wait 5 min fire it up give it a lil neutral rev and the temp settles at 170... I say what the hell take it out if the no wake zone and get it on plane.. after 3-4 min I drop back to neutral... temp imidiately climbs... I shut it down and call a tow
i didn’t shoot it with a temp gun but both risers are hot to touch..
frustrated, defeated... but happy I made it home safe and got to give my two boys a bubble bath tonight..
2000 5.7 gsi pwtr. Sx-m 1:43
any idea where to go from hear????
