just google GM crate motor....plenty of them out there, including your local GM dealer.
if your going to build a stroker, you can either buy the HT383 GM long block (already done) or you can buy new GM block, scat rotating assembly, new GM vortec heads and a comp cams K-kit. only machining you would need to do is modify the vortec heads for screw in studs and larger lift (about $100)
