mtntrogger
- Apr 29, 2013
- 41
Hello friends, I am desperately in need of some guidance and am hoping someone on here can help put me on the right track.
I recently bought a new used boat that has a Volvo penta engine which has been giving me some problems. So the engine decal on the fuse/relay cover on the engine says its the 5.0 GLPEFS model, However the previous owner told me that the engine was replaced in 2016 with a crate motor. He said that the new engine is the 5.7 not the 5.0. It is painted black/charcoal not red so its possible that this is a 2000 vintage motor. Can anyone help me with the ID of the engine ? It has a holley carb on it, which I believe is a 2 barrel.
The engine seems to not be getting fuel. It isnt very easy to cold start, generally requires several attempts. Usually, if I disengage the transmission and move the throttle lever all the way forward, I can get it to fire. Ive only had it out a few times, but once its running, it performs very well. Tons of power and also putts around at low speed very comfortably. The last couple of times out, it stalled out after being out for a short while and would not restart.
After getting a tow back to the dock, I attempted to see what was going on. I tried to spray starting fluid into the carb while my buddy tried cranking the key, She would fire for a second, but wouldnt stay running. The Marina mechanic took a quick look also. He had me "prime" the throttle while cranking, he was looking into the carb and noted that there was no fuel coming in.
I know these problems can be electrical sometimes. Since the engine (supposedly) has only 50 hours I wouldnt presume that the pump would already be failing (IF it was replaced with the engine). I attempted to test the relay near the fuel pump with a voltmeter....but honestly am not sure what I should be probing and what reading I should be looking for. From what I can tell the pump is getting power. This leads me to believe that the pump is the only possible solution. I just dont want to throw money at this thing haphazardly. Im hoping someone on here can help me out with what/how to test/diagnose this and also how to positively ID this motor. Thanks very much for any input, I really appreciate you guys
