yooper49868
- Feb 1, 2017
- 5
Best Manual for VolvoPenta OUTDRIVE (not engine) maint & repair ??
...Hello to the more experienced sailors out there…
...I am a new owner of a 1993 GlassTron with a Volvo Penta 4.3 L GM block.
Engine 430B / P5 4100 141230 868527
Outdrive is labeled SP-CD Trim. Some of the transom parts are stamped with a 1992 date.
During winterizing, I drained lube oil from bottom of the outdrive and saw that it was milky with water. Second time this has happened.
… I have been told that I need to replace prop shaft seals. Also the bellows need work.
… So Here Is the Question: What is the best manual I can get for service work on the OUTDRIVE. I looked at Seloc Manual #3606, but that seems to have more info on the engine and not much on the outdrive.
… Any tips? Would be very grateful for your help.
Yooper Yacht Club
Yooper Yacht Club
