Have had my boat for about a year - 4.3GL-J, with the stock holley 2 barrel carb. I get some sooty residue along the water line at the back of the boat, and plugs look a little sooty when I pulled them out to inspect, so was guessing that the idle might be a hair rich. Looking at the carb though, there are some sort of caps installed over the idle air adjustment screws on the sides of the metering block, and the metal was punched down a little bit over the caps so that they will be real hard to remove. Is this some sort of california thing to prevent people from changing settings? Any way to remove without damaging other things?
